Nye Team Associated SC10 4x4
SC10 4x4 Kit
1:10 Scale 4WD Electric Short Course Truck Kit. Experience the thrill of four-wheel-drive action and performance with the SC10 4x4!
Features
Vehicle Specifications
* This vehicle comes as a kit and must be fully assembled by the user. Electronics and/or an engine/motor may be required.
Required to Complete
Forhåndsbestilt på Amainhobbies
Bent
SC10 4x4 Kit
Features
- Unique dual gearbox drive train coupled together with a 5mm heavy duty belt system with external tension adjustment
- 32 pitch front and rear gearboxes with sealed fluid filled differentials
- Decoupled center slipper clutch allows for front and rear wheel drive to slip independently, resulting in more traction and stability on bumpy track conditions
- CVAs with captured drive pins and heavy duty 6mm alloy axles
- 12mm hex drive KMC® replica wheels front and rear with aggressive short course racing tires
- Championship short course racing body (clear), with Team Associated decal sheet
- 13mm blue aluminum big-bore threaded shocks with low friction X-ring seals
- Composite modular tub chassis with Low-CG and Low Polar Moment design
- Enclosed water-resistant receiver box, and removable ESC tray for easy clean up and maintenance
- Ball bearing steering system with adjustable steering stops
- All metric hardware and ball bearings throughout
- Uses most 540 and 550 brushless motors
- Power Source: Electric
- Terrain: Off-Road
- Body Style: Truck
- Scale Size: 1:10 Scale
- Assembly Level: Kit*
- Length: 550mm (21.65in)
- Width: 293mm (11.54in)
- Wheelbase: 327mm (12.87in)
- Weight: 2775g (6.12 lbs)
- Internal Gear Ratio: 2.57:1
- Drive: 4WD
- R/C 2-channel surface frequency radio system
- Battery pack (6 cell NiMh or 2 cell LiPo)
- Battery charger (peak detection charger recommended)
- Electronic speed control
- R/C electric motor (550 size recommended)
- Pinion gear
- Tire glue
- Paint for body
- Steering servo
Bent
