Motorregisteret
  • #61
    Merke: Scorpion
    Modell: RS3420 4.5T
    Godkjent for: IFMAR
    Stator Diameter 34 mm (1.34 in)
    Stator Thickness 21 mm (0.83 in)
    No. of Stator Arms 3
    No. of Stator Poles 2
    Motor Wind 4.5T Y
    Motor Wire 1-Strand 2.46 mm
    Motor Kv 7170KV RPM/Volt
    No-Load Current (Io/7.8V) 6.7 Amps
    Motor Resistance (RM) 0.041 Ohms
    Max Continuous Current 95 Amps
    Max Continuous Power 703 Watts
    Weight 167.2 Grams (5.9 oz)
    Outside Diameter 36 mm (1.41 in)
    Shaft Diameter 3.17 mm (0.12 in)
    Body Length 52.65 mm (2.07 in)
    Overall Shaft Length 67.4 mm (2.65 in)
    Max Lipo Cell 2s
    Max Peak Current 114 (2 seconds)
    Max Peak Power 850 Watts (2 seconds)
    Motor Timing Adjustable deg
    Drive Frequency 8kHz
    ᕦ(ò_óˇ)ᕤ
