Team Associated Factory Team 12R5.1 (1:12)
  • Team Associated Factory Team 12R5.1 (1:12)
    Factory Team 12R5.1 (På lager hos Hobby24.no i Februar)
    Oppdatert : Pris er 1795,-
    The Factory Team 12R5.1 is the latest evolutionary step in Associated’s twenty-five years of 1:12 scale racing history. New for the RC12R5.1 is the wide three-point rear pod that has been optimized for fitting brushless motors as well as heat dissipation. The 12R5.1 is built on a 2.5mm woven carbon fiber chassis that utilizes a pivot-ball link rear suspension that allows for independent adjustments for chassis roll, bump, and alignment.
    Having the ability to make these chassis adjustments independently gives the 12R5.1 greater potential for the best possible handling on any track surface. While testing, the pivot-ball link chassis has proven to be more durable in high-speed impacts and excels in bumpy track conditions.
    The 12R5.1 features shocks with a through-shaft design providing equalized damping throughout the full stroke of the shock in both directions without any unwanted rebound. The center shock tower has four mounting positions that split the spring rates for even finer adjustments. The center shock also controls the chassis droop and can be adjusted on the car with a turnbuckle wrench, making it easier and quicker to get dialed in.
    The 12R5.1's "Active Strut" front end has been optimized, featuring symmetric components with adjustable caster and track width, as well as a front axle with wheel nut. Factory Team blue aluminum servo mounts position the servo flat on the chassis for a lower center of gravity and include Ackermann adjustment spacers. The foam front bumper helps protect body and chassis during impacts.
    The 12R5.1 comes ready for brushless with a new optimized wide rear pod. The rear pod features a woven carbon fiber top plate and Factory Team blue aluminum machined motor mount, left side bulkhead and motor mount standoff. The woven carbon fiber top plate attaches to the motor mount and left side bulkhead at three points, and uses an integrated standoff, making the rear pod more rigid. Front-to-rear chassis balance is optimized at the center of the battery, allowing an easy transition to 3.7V LiPo batteries.
    Features
    • Wide rear pod allows easy installation of brushless motors and features Factory Team blue aluminum machined motor mount, left side bulkhead, and standoff.
    • Accepts single-cell LiPo battery packs without changing the front-to-rear weight bias.
    • Factory Team shocks feature a through-shaft design, making for equal damping with no rebound in both directions.
    • Active strut front end features symmetric components with adjustable caster and track width, as well as a new front axle with wheel nut.
    • Woven carbon fiber center shock tower allows for incremental adjustments of rear spring rate.
    • Factory Team pivot ball-link chassis allows for independent adjustment for roll, bump, and alignment.
    Items Needed: 12R5.1 Factory Team
    • R/C 2-channel surface frequency radio system
    • Batteries (4 cells, laid out 2x2, not as stick pack)
    • Battery charger (peak detection charger recommended)
    • Electronic speed control
    • R/C electric motor
    • Pinion gear
    • 1:12 scale body
    • Paint for body
    • Tires
    • Glue for tires
    • Steering servo for 1:12 scale
    • Tools: Hex wrenches, hobby knife, needlenose pliers, wire cutters, Lexan scissors (#1737)
    • Other suggested items: Reamer/hole punch, CA glue (#1597), thread-locking glue (#1596), silicone fluid
    Specs: 12R5.1
    Factory Team 12R5.1 #4019 Scale 1:12 Power Electric Type On Road Pan Car Length 265mm Width 170mm Weight 830g Wheelbase 196mm Internal Gear Ratio 1:1 Drive 2WD/RWD
      Posting comments is disabled.
    Article Tags
    Latest Articles
    • Article with Video
      by xilian
      5 August 2016, 23:04
    • 2012 IFMAR WORLDS IN THE NETHERLANDS
      by xilian
      The MACH is proud to present a full line-up of r/c industry sponsors to support the 2012 IFMAR Worlds 1:10 and 1:12 scale electric in Heemstede, the Netherlands. Only with the financial support of our sponsors it is possible to organize the 2 major events.
      2 May 2012, 12:50
    • GTL RC-Klubb inviterer til Norgesmesterskap og RC-messe
      by >Jonas<
      Første helga i mars blir det høy fart i Gjøvik Tennishall. Da arrangeres det RC-messe og Norgesmesterskap i klassene 1:10 Touring og 1:12 Track, med kvalifisering på lørdag og finaler på søndag. Det arrangeres også åpent klubbløp i Tamiya M-chassis begge dager. Gjøvik og omegn modellflyklubb kommer for å ha oppvisning, det samme gjør noen av Norges beste RC-driftere. Noen norske RC-butikker kommer også på besøk. Gratis inngang, kiosk med mat og drikke, og muligheter for å vinne flotte premier, s...
      16 February 2012, 19:26
    • Ny batteriserie fra JackPower
      by xilian
      Jackpower lanserer i disse dager en ny serie med batterier.
      Den nye serien vil kunne levere 65C kontinuerlig, og 130C i peak (10sek)
      De nye cellene vil kunne lades med opp til 8C. Det betyr ladetid ned mot 7,5 minutter.
      Eksempelvis vil 3S 2200mah koste ca 300kr (+/- 10%)
      6S 5000mAh vil koste rundt 1500kr. Disse leverer 325A kontinuerlig og 650A i peak.
      Hobby24 vil få inn den nye serien helt i starten av 2012. Hobby24 søker også forhandlere for de som m...
      22 November 2011, 13:35
    • SUMO-utstyr stjålet fra UiB
      by xilian
      Det ble i helgen stjålet viktig utstyr fra Geofysisk institutt fra Universitet i Bergen (UiB)
      Følgende utstyr er savnet:
      • 3 SUMO systems with autopilot, data logger and sensors (serial numbers 4,7,9)
      • 1 field PC Panasonic Toughbook CF-19 (SNR:7JKCA88527,UiB-tellekort:00185521)
      • 1 remote control Graupner MC 22
      • 2 modems for communication between aircraft and ground control station
      • 2 antennas
      • 8 batteries LiPo 2.2 Ah
      • 1 box with cables, connectors and spare parts
      29 November 2010, 18:12
    • Sørlihavna Drift Battle 2010
      by Retteråsen
      RCDCN kjører igang konkurranse søndag 3 oktober, på LMBK sitt flotte baneanlegg i Lørenskog, Sørlihavna. Her blir det avslutning av utesesongen 2010. Konkurranse i kjent RCDCN stil. Med kvalifiserings kjøring først, derav de 16 beste etter kvalifisering får være med å kjempe om toppen i Twindrift!
      17 September 2010, 00:10
