mini z drifting
  • mini z drifting
    Hei netop anskafet meg en mini z awd tenkte å bruke den til drifting noen som har et godt opset å bruke på mini z til å drifte med?
    Go Fast or go away
    Originally posted by art3ria View Post
    I have CounterSteer in my MA015, the max effective CS that you can get is 144% because you can't add more direction angle, more CS without more direction angle is not effective.
    To get this you have to modify the centershat in the front side and add 6t Pinion, we have some prototypes in testing to produce it and sell.
    you can add modify to get 10T pinion at rear but you will get a lower ratio that can be dangeorus to your ESC.
    I come from 1:10 Drift RC. and i use similar setup in my own MA015:
    Fron Camber: -1º/-2º .
    Front Suspension: I.A.S : White Regular Atomic AWD Springs.
    Front Diff Gear :EagleRacing Diff: 6T Pinion - 28T Spur.
    Front Toe :-1º.
    Rear Camber: 0º
    Rear Suspension: S.A.S : White Atomic SAS Springs.
    Rear Diff Gear: 3Racing Spool : 8T Stock Pinion 26T Spur.
    Rear Toe: 1º.
    Tires: Kyosho Narrow Dirift Tires Front&Rear.
    Motor Kyosho XSpeed.
    Ratio: 19T-29T.
    Cs 144%
    Wheel Base 90mm with a S2000 Body but with CS has better performance to drift in 94mm
    Sorry my bad English.
    Fant denne på en annen side. Kan du bruke den?
      hmm litt usiker den snakker om å måtte modde alt :S men deler av den kan jeg bruke
      Go Fast or go away
