Team Losi 1/10 Comp Crawler
  • Team Losi 1/10 Comp Crawler
    Heisann!
    Nå kommer Losi med en ny crawler i "riktig" skala. De vil også lansere en ny serie Li-PO batterier og børsteløst til Crawler-bruk.
    1/10 Comp Crawler Race Roller
    At a Glance
    Incorporating real engineering elements from full-size rock crawling competition, the 1/10 Comp Crawler represents the pinnacle of RC rock crawling design. Every part, every feature and every inch is designed to mimic real-world competition platforms, resulting in the most advanced 1/10-scale radio control crawler ever developed.
    The list of innovations that make the Comp Crawler an RC revolution is long, and it starts with a solid foundation. The Twin Vertical Plate (TVP) chassis with adjustable upper shock mounts offers unbeatable stability and rigidity in a durable, lightweight design. The result is confident handling over any terrain and outstanding suspension articulation. And Team Losi Racing has gone one step further, by offering this innovative crawling chassis pre-built and tuned right out of the box. All you have to do is add the electronics of your choice and paint the included Lexan Grapler Pro body.
    Team Losi Racing’s Comp Crawler is the first rock crawling platform in the industry to offer a revolutionary front and rear “dig” transmission. The use of an optional third channel setup allows the front or rear drive axle to be disengaged, locking the wheels in place and acting as a steering brake for precise lateral movement on and over obstacles. The transmission case has been fitted with adjustable servo mounts that will allow for the use of most “mini” servos and includes an aluminum servo arm. The third channel on a 3-channel radio (such as the Spektrum DX3R) allows the full use of the DIG transmission, and also requires a micro servo installation for actuation. If you do not have a 3-channel radio system or extra servo there is no need to worry - the Comp Crawler will function with full time 4wd with our without a dig servo hooked up.
    The solid axle setup on the Comp Crawler offers a significant reduction in flex for improved performance. Inside, the axles utilize a worm gear drive for outstanding precision in throttle control and maneuverability. Another benefit of the worm gear drivetrain design is the elimination of the “torque twist” commonly found in shaft driven rock crawlers. As a result, the Comp Crawler stays in contact with the ground for uninterrupted grip.
    The Comp Crawler features a 4 link suspension layout that offers 70 degrees of suspension articulation. This specially designed 4-link suspension setup is used in combination with the twin vertical plate chassis to reduce axle swing and eliminate side-to-side movement for increased steering and maneuvering precision. 7mm diameter aluminum suspension links are hard anodized and triangulated to the center of the chassis for better balance front to rear when the suspension starts to twist. 4” Aluminum threaded shocks with Titanium Nitride (TiNi) shafts allow the suspension to articulate without any binds.
    Designed with the demanding conditions of competition rock crawling in mind, the steering system on the Comp Crawler provides precise control as well as class leading performance with 45 degrees of steering throw. The front caster blocks feature 10 degrees of caster and the spindles are attached with heavy duty steel king pins. The steering geometry also allowed Team Losi Racing engineers to raise the main steering link closer to the axle housing, giving the Crawler additional clearance when approaching obstacles.
    Just like full-size crawlers, the 1/10 Comp Crawler utilizes functional beadlock wheels with aluminum outer rings. The functioning beadlock allows for the tires to maintain more contact and traction, while the aluminum outer rings provide evenly distributed pressure for unbeatable tire mounting. Losi’s National Champion Rock Claws 2.2 Tires come mounted on the beadlock wheels, complete with foam inserts. The added ground clearance from the Rock Claws tires makes conquering any and all courses easier.
    Features
    Compact Front & Rear Locking (DIG) Center Transmission allows the crawler to overtake obstacles with ease
    Front and Rear Solid Axle with Worm Gear Drive
    4-Link Suspension offers 70 degrees of articulation and minimizes front and rear axle swing, allowing for more precise handling
    Zero Ackerman Steering provides class leading performance with 45 degrees of steering throw
    Front and Rear locked differential provides full time 4wd
    3-Piece 2.2" Bead Lock Wheels with aluminum outer rings
    National Champion 2.2 Losi Rock Claws Tires with foam inserts
    Twin Vertical Plate Chassis with adjustable upper shock mounts
    4" Aluminum Threaded Shocks with Titanium Nitride (TiNi) Shafts allow the suspension to articulate without any binds.
    Durable, telescoping CV drive shafts allow for increased steering range
    Aluminum Upper and Lower Suspension Links for added strength
    Lexan Grappler Pro body is optimized to USRCCA Rules and allows for clearance of the tires as they articulate
    Race Roller Chassis is preassembled; simply add electronics, paint the body and go
    Product Specifications
    Type:Competition 2.2 Rock Crawler Race Roller
    Scale:1/10 (2.2)
    Length:17.5 inches (444.5mm)
    Width:10.5 inches (266.7mm)
    Wheelbase:12.5 inches (317.5 mm)
    Weight:4.18 lbs. (1.9kg)
    Chassis:Twin Verticle Plate
    Suspension:4-Link
    Tire Type:National Champion Losi Rock Claws 2.2
    Wheel Size:2.2" Bead Lock
    Kit/RTR:Race Roller
    Shock Type:4" Aluminum with Titanium Nitride (TiNi) shafts
    Body:Clear Lexan Grappler Pro
    Completion Guides
    Basic
    Advanced
    Needed to Complete
    Basic set-up
    • 17.5 T Brushless Motor and ESC (LOSB9553 Xcelorin Sensored 17.5T ESC/Motor Combo)
    • 2-3-Cell LiPo (LOSB9865 11.1V 1350mAh 3S 20C LiPo)
    • Charger for above battery (LOSB9605 Intelligent Lithium Charger)
    • High torque Steering Servo (Min. of 200oz) (JRPSZ9100T Digital Ultra-Torque MG Servo)
    • 2 Channel Radio System
    • Paint
    Advanced Completion: To take full advantage of the DIG set-up and the true potential of the 1/10 Comp Crawler
    • 3-Channel Radio System w/ 3 position 3rd channel switch (SPM3130 DX3R DSM2 Radio System)
    • Mini Steering Servo (LOSB0822 MSX12 Digital Mini Servo)
    Losi has performance you can depend on. Losi RC cars, RC trucks, and RC buggies leverage innovative designs with scale realism perfect for racing with friends or competing.
    Flere enn meg som fikk lyst på denne?
    Fabiz
    Smallsize Hobbyland A/S
    Team Losi : Spektrum
    Ja.Når regner dere med å få denne inn i butikken da ?
    Paul-Erik Bastiansen.74.Vestby.Sjef.
      Offisiell lanseringsdato ifra Losi US er jo Late Mars,
      Så da har vel smallsize den i løpet av Sommern tenker jeg.
      RC4WD Team Driver
        Det er ennå uvisst når denne kommer til Smallsize, men i løpet av senvåren tenker jeg.
        Fabiz
          Fabiz
          Da sier vi Desember '09, så kanskje vi treffer:P
          Martin Sørlie - 1985
          TLR - Absima - Spektrum
          Darkspeed Racing
          www.teamsmallsize.com
            å det er en så fin bil å se på :P helt forelsket i den men noen som vet en cirka pris å få den til norge fra USA?
