team loosin rock crawler
er dette bra?
x Team Losi (#LOSA0051) 1/10 Comp Crawler Race Roller USD$279.90 USD$20.00
x Team Atlas (#AT7-14
Rock Climer Motor 80T 5940RPM USD$24.90 USD$3.00
x LRP (#83250) A.I. Automatic Pro Reverse Digital Speed Controller USD$82.90 USD$13.00
x *Combo (#CB0239) Extreme (#X-605) Li-Po Balance Charger + SuSuMu Li-Po Battery 7.4V 3200mAh 20c x 2pcs USD$139.70 USD$39.80
x Ansmann Racing (#132000040) W3 2.4G Radio Control System USD$99.90 USD$0.00
x Blue Bird (#BMS-620) High-Torque Servo USD$19.90 USD$0.00Jan Erik Bråten, 27 år
Subaru Impreza landmax2, Mad Force
Nitro tracker, Raptor 50, Corally RDX
Hvis du vil så kan du bruke børsteløst, men i Norge kjører de fleste med børstemotorer.Originally posted by tesdal View PostBruker man ikke børsteløst til crawler? Tenker at ESC ikke helt står i stil med prisnivået på de andre tingene.
passer dette da
Product ID: rcps81709_13t
13T/35A ESC Brushless System for 1/10/1:12 R/C Car
Details
Specification:
kv of motor : 3032rpm/v
Cont. Current of ESC : 35A
Burst Current of ESC : 190A
Resistance : 0.0015 ohm
Suitable Car : 1/10 or 1/12 Car
Recommended Battery : 4-9 Cell NiMh or NiCd, 2-3 Cell Li-Poly Battery
Running Mode : Racing and Reverse
Reverse force adjustment : 4 options
Proportional ABS brake adjustment :
- brake force (4 options)
- drag brake force (8 options)
- initial brake force (4 options)
Start Mode : 4 options (from soft to very aggressive)
Timing adjustment : 8 options
Protection features :
- Low-voltage cut-off protection
- Over-heat protection
- Throttle siginal loss protection
- Motor blocked protection
Weight of motor : 169g
Weight of ESC : 56.5g
Weight of Program Card : 39.5g
Size of ESC (mm) : 40.6 X 27.4 X 32.3
Size of Program Card (mm) : 88.6 X 58.4 X 14.8
Packaging Weight : ~425gJan Erik Bråten, 27 år
Active Members: 1
