Team Orion Experience 2 Pro BL for Short Course Trucks!
  • Team Orion Experience 2 Pro BL for Short Course!
    Team Orion proudly presents the Experience 2 Pro Brushless System for Short Course Trucks!
    Short Course Racing
    Short Course Racing has never been more popular – not only backyard bashers love the trucks, also racers were attracted by the Short Course action. Just lately Team Orion super star Jared Tebo won the Short Course Showdown held at Trackside Hobbies in Milwaukee!
    Maximum power, best drivability
    Team Orion developed an all new Brushless System with only one goal: deliver more power, more speed and more punch to Short Course trucks! We always kept in mind to give the driver perfect feel and drivability. Like this the Experience 2 Pro Brushless system was born!
    Great compatibility with Short Course trucks on the market
    Hundreds of testing hours have been invested to develop the optimal brushless system for the short course application. The system has been tested in the Short Course trucks available on the market to provide best compatibility!
    Perfect fit into Traxxas® Slash®
    To fit the very popular Traxxas® Slash® short course truck, the large size heatsink features two mounting holes. Like that the speedo can be installed in the car with two screws – exactly like the standard ESC of the Slash® ! It also comes standard with the TRX® high power connector.
    Easy to install, easy to use!
    The Brushless system is equiped with all the goodies from the well known Experience 2 Brushless technology like automatic setup and plug&play technology.
    Features
    - High Power Brushless System for Short Course Trucks
    - Experience 2 Pro 3750KV High Power Motor, 550sized
    - Experience 2 Pro Sensorless Brushless speed control with integrated cooling fan
    - Plug&Play Technology
    - Automatic Setup
    - TRX® Connector
    - Direct fit on Traxxas® Slash® and many other Short Course Trucks
    - Optimal ESC/Motor Combo
    Part Numbers
    ORI66045 Experience 2 Pro Combo (motor+controller with fan)
    ORI28179 Experience 2 Pro Motor
    ORI65016 Experience 2 Pro Controller
    Sources
    > Instruction Manual
    > High resolution pictures
    > Catalog Page
    > Brushless Information Sheet
    Technical Specifications
    ESC (ORI65016): BL system: sensorless; Functions: Forward/Brake/ Reverse; Battery connector: TRX®; Input voltage: 6-8 cells NiMH/NiCd, 2-3 cells LiPo/LiFe; Max current: 70A; Peak current: 360A; BEC: 6V 2A; Weight: 88g; Dimensions: 52.5x45x24mm; Can be used with the Vortex DSB (ORI65020)
    10T Motor (ORI28179): Input voltage: 6-8 cells NiMH/NiCd, 2-3 cells LiPo/LiFe; Max current: 70A; Peak current: 90A; Resistance: 0,0083Ohm; No load current: 2.8A; Winding: 10T; RPM/V: 3750KV; Shaft length: 16.5mm; Shaft diameter: Ø 3,175mm; Dimensions: 38x56mm; Weight: 234g
    Traxxas® TRX® High Current Connectors US Patent Nos. 7,374,460, 7,530,855, D573,536 and D576,557; Traxxas, Slash and TRX are registered trademarks of Traxxas, L.P.
    • Maxxi
      #5
      Maxxi commented
      Editing a comment
      Noen som aner noe pris på denne ?
      HVordan er denne i forhold til den orginale vanntette vxl ?
    • Martin K.
      #6
      Martin K. commented
      Editing a comment
      Synes VXL var veldig bra skal teste et sensored fra novak SS pro i min sc10 nå. blir mer presist og har mer instillings muligheter, VXL'n er litt for enkel, men en sterk og god motor og reg, den har jo faktisk også sensor inngang, noe jeg aldri testet på den.
    • ofnacrucher
      #7
      ofnacrucher commented
      Editing a comment
      vil denne fungere i en slash 4x4 uten å bli overopphetet?
    Posting comments is disabled.
Article Tags
Latest Articles
  • Article with Video
    by xilian
    5 August 2016, 23:04
  • 2012 IFMAR WORLDS IN THE NETHERLANDS
    by xilian
    The MACH is proud to present a full line-up of r/c industry sponsors to support the 2012 IFMAR Worlds 1:10 and 1:12 scale electric in Heemstede, the Netherlands. Only with the financial support of our sponsors it is possible to organize the 2 major events.
    2 May 2012, 12:50
  • GTL RC-Klubb inviterer til Norgesmesterskap og RC-messe
    by >Jonas<
    Første helga i mars blir det høy fart i Gjøvik Tennishall. Da arrangeres det RC-messe og Norgesmesterskap i klassene 1:10 Touring og 1:12 Track, med kvalifisering på lørdag og finaler på søndag. Det arrangeres også åpent klubbløp i Tamiya M-chassis begge dager. Gjøvik og omegn modellflyklubb kommer for å ha oppvisning, det samme gjør noen av Norges beste RC-driftere. Noen norske RC-butikker kommer også på besøk. Gratis inngang, kiosk med mat og drikke, og muligheter for å vinne flotte premier, s...
    16 February 2012, 19:26
  • Ny batteriserie fra JackPower
    by xilian
    Jackpower lanserer i disse dager en ny serie med batterier.
    Den nye serien vil kunne levere 65C kontinuerlig, og 130C i peak (10sek)
    De nye cellene vil kunne lades med opp til 8C. Det betyr ladetid ned mot 7,5 minutter.
    Eksempelvis vil 3S 2200mah koste ca 300kr (+/- 10%)
    6S 5000mAh vil koste rundt 1500kr. Disse leverer 325A kontinuerlig og 650A i peak.
    Hobby24 vil få inn den nye serien helt i starten av 2012. Hobby24 søker også forhandlere for de som m...
    22 November 2011, 13:35
  • SUMO-utstyr stjålet fra UiB
    by xilian
    Det ble i helgen stjålet viktig utstyr fra Geofysisk institutt fra Universitet i Bergen (UiB)
    Følgende utstyr er savnet:
    • 3 SUMO systems with autopilot, data logger and sensors (serial numbers 4,7,9)
    • 1 field PC Panasonic Toughbook CF-19 (SNR:7JKCA88527,UiB-tellekort:00185521)
    • 1 remote control Graupner MC 22
    • 2 modems for communication between aircraft and ground control station
    • 2 antennas
    • 8 batteries LiPo 2.2 Ah
    • 1 box with cables, connectors and spare parts
    29 November 2010, 18:12
  • Sørlihavna Drift Battle 2010
    by Retteråsen
    RCDCN kjører igang konkurranse søndag 3 oktober, på LMBK sitt flotte baneanlegg i Lørenskog, Sørlihavna. Her blir det avslutning av utesesongen 2010. Konkurranse i kjent RCDCN stil. Med kvalifiserings kjøring først, derav de 16 beste etter kvalifisering får være med å kjempe om toppen i Twindrift!
    17 September 2010, 00:10
