Stooor marine regulator...hjelp!!
  • Stooor marine regulator...hjelp!!
    Er det noen som vet om en eller hvor man kan få kjøpt en stor marine regulator? Må være 300 amp +++ og tåle 14s lipo+++!! Trenger virkelig hjelp her litt hurtig
    Det er ikke godt nok og være nest best!
    her vil være en http://www.atos-modellsport.com/produkte/formelwk
    Hilsen kelle
    Miss Hyde, Zardos, Genessis
      eller du må leite etter FighterCat LV Mariene ESC
      eller dette http://www.espritmodel.com/jeti-spin...hless-esc.aspx
      Hilsen kelle
        FighterCat HV Marine ESC 16s 300a
        Full voltage tested (72v) with 4 pole, 6 pole, 8 pole, 10 pole and 12 pole motors.
        Max Constant Current: 300A
        Max Current: TBD
        BEC: OPTO
        PWM: 8 KHz 16 KHz 32KHz (8khz preferred)
        Input: 3 to 17s LiPo (16s preferred max)
        Physical size: 145mm x 50mm x 8mm (long and thin to dissipate heat evenly) = 6" x 2" x 1/2" approximately
        Programming options:
        Battery Type, Number of cells/auto, LVC Voltage & Cutoff type
        Power Limit Forward & Reverse, 25, 50, 75 & 100%
        Throttle Curve, Logarithmecal, linear, exponential
        Acceleration, Soft, Medium & hard
        Timing in 1 degree increments 1-30 degrees (Timing MUST be properly set or will cause failure)
        Delay time, .25S to 5S
        Timing Monitor, on/off (timing monitor will beep the timing setting when plugging in the ESC)
        Reverse, on/off (turns off brake too)
        FighterCat HV Marine ESC 16s 400a
        Max Constant Current: 400A +
        Max Current: TBD EST 600A +
        BEC: OPTO
        Physical size: 145mm x 50mm x 24mm (long and thin to dissipate heat evenly) = 6" x 2" x 1 1/2" approximately
        Hilsen kelle
          or dette fra schulze men de kost 750 €
          Successor of the 40.303WK with improved current measurement at low currents
          5-14 Li-cells <=> 18-40 Ni-cells
          300 A (400 A)
          Opto-coupler
          Splash water protection
          Water cooling
          Used in a HPR 233 - own Video -
          Hilsen kelle
            og her en fra privat men alltri brukt. Jeg kan snakke med ham om du har interesse.
            Hilsen kelle
