Er det noen som vet om en eller hvor man kan få kjøpt en stor marine regulator? Må være 300 amp +++ og tåle 14s lipo+++!! Trenger virkelig hjelp her litt hurtig
Stooor marine regulator...hjelp!!
her vil være en http://www.atos-modellsport.com/produkte/formelwkHilsen kelle
Miss Hyde, Zardos, Genessis
eller du må leite etter FighterCat LV Mariene ESC
eller dette http://www.espritmodel.com/jeti-spin...hless-esc.aspxHilsen kelle
FighterCat HV Marine ESC 16s 300a
Full voltage tested (72v) with 4 pole, 6 pole, 8 pole, 10 pole and 12 pole motors.
Max Constant Current: 300A
Max Current: TBD
BEC: OPTO
PWM: 8 KHz 16 KHz 32KHz (8khz preferred)
Input: 3 to 17s LiPo (16s preferred max)
Physical size: 145mm x 50mm x 8mm (long and thin to dissipate heat evenly) = 6" x 2" x 1/2" approximately
Programming options:
Battery Type, Number of cells/auto, LVC Voltage & Cutoff type
Power Limit Forward & Reverse, 25, 50, 75 & 100%
Throttle Curve, Logarithmecal, linear, exponential
Acceleration, Soft, Medium & hard
Timing in 1 degree increments 1-30 degrees (Timing MUST be properly set or will cause failure)
Delay time, .25S to 5S
Timing Monitor, on/off (timing monitor will beep the timing setting when plugging in the ESC)
Reverse, on/off (turns off brake too)
FighterCat HV Marine ESC 16s 400a
Max Constant Current: 400A +
Max Current: TBD EST 600A +
BEC: OPTO
Physical size: 145mm x 50mm x 24mm (long and thin to dissipate heat evenly) = 6" x 2" x 1 1/2" approximately
Reverse, on/off (turns off brake too)Hilsen kelle
or dette fra schulze men de kost 750 €
Successor of the 40.303WK with improved current measurement at low currents
5-14 Li-cells <=> 18-40 Ni-cells
300 A (400 A)
Opto-coupler
Splash water protection
Water cooling
Used in a HPR 233 - own Video -
Hilsen kelle
og her en fra privat men alltri brukt. Jeg kan snakke med ham om du har interesse.
Hilsen kelle
