Team Associated SC10 4x4
  • Team Associated SC10 4x4
    Nye Team Associated SC10 4x4
    SC10 4x4 Kit
    1:10 Scale 4WD Electric Short Course Truck Kit. Experience the thrill of four-wheel-drive action and performance with the SC10 4x4!
    Features
    • Unique dual gearbox drive train coupled together with a 5mm heavy duty belt system with external tension adjustment
    • 32 pitch front and rear gearboxes with sealed fluid filled differentials
    • Decoupled center slipper clutch allows for front and rear wheel drive to slip independently, resulting in more traction and stability on bumpy track conditions
    • CVAs with captured drive pins and heavy duty 6mm alloy axles
    • 12mm hex drive KMC® replica wheels front and rear with aggressive short course racing tires
    • Championship short course racing body (clear), with Team Associated decal sheet
    • 13mm blue aluminum big-bore threaded shocks with low friction X-ring seals
    • Composite modular tub chassis with Low-CG and Low Polar Moment design
    • Enclosed water-resistant receiver box, and removable ESC tray for easy clean up and maintenance
    • Ball bearing steering system with adjustable steering stops
    • All metric hardware and ball bearings throughout
    • Uses most 540 and 550 brushless motors
    Vehicle Specifications
    • Power Source: Electric
    • Terrain: Off-Road
    • Body Style: Truck
    • Scale Size: 1:10 Scale
    • Assembly Level: Kit*
    • Length: 550mm (21.65in)
    • Width: 293mm (11.54in)
    • Wheelbase: 327mm (12.87in)
    • Weight: 2775g (6.12 lbs)
    • Internal Gear Ratio: 2.57:1
    • Drive: 4WD
    * This vehicle comes as a kit and must be fully assembled by the user. Electronics and/or an engine/motor may be required.
    Required to Complete
    • R/C 2-channel surface frequency radio system
    • Battery pack (6 cell NiMh or 2 cell LiPo)
    • Battery charger (peak detection charger recommended)
    • Electronic speed control
    • R/C electric motor (550 size recommended)
    • Pinion gear
    • Tire glue
    • Paint for body
    • Steering servo
    Forhåndsbestilt på Amainhobbies
    Bent
    Xray XB8 | Xray XB8E | Xray XB4 | Xray XB4 2WD | Xray T4 | Xray X12
    Xray Factory Team | ORCA Factory Team | FX-Engines Factory Team
    Hudy | Sweep Racing | Maxima Fuel | Antrade.no | rcMart.com | YeahRacing | IB-Prostart | Freqeskinz.com
    Follow Malin on Facebook
    Noen flere bilder hentet fra www.rccaraction.com:
    Bl.a bilder av den justerbare front one way clicker'en
      Noen til.....
      Bent
        Team Associated SC10 4x4 1/10 Scale Electric 4WD Short Course Race Truck Kit
        Mustit Rc
        Kommer til å ta inn nye SC10 4x4 fra Ass
        Vi har ikke fått prisen fra grossisten ennå men vi kommer tilbake med det
        Mvh
        Asim
        Mustit RC
        www.bmrk.net * Hotbodies * Assosiated * Scumacher * Savöx * Jconcepts * Nosram * Epic Trinity *
          Originally posted by mustitRC View Post
          Mustit Rc
          Mvh
          Asim
          Mustit RC
          Høres knall ut
          Send meg gjerne en PM når dere får pris/leveringstid.
          Har forhåndsbestilt på Amain, men handler gjerne her hjemme hvis prisen ikke er helt horribel
          Bent
            Vi skal nok klare matche prisen til amain
            Originally posted by BentKa View Post
            Høres knall ut
            Bent
              Bare å vente på en PM da
              Bent
                25 min langt video intervju med en av designerne bak Associated's SC10 4x4:
                Bent
                  Ikke lenge igjen nå
                  Bent
                    Denne bilen ser meget lovende ut. Noen som har tenkt ut hva slags ESC/motor kombo som vil passe? Jeg vet bilen skal funke med både 540 og 550, men logikken tilsier at dreimomentet i en 550 er kjekt å ha i en litt tyngre bil. Tenker da primært på Novak Ballistic 550, Tekin SCX4 eller LRP X12 550. Hva med ca turn/Kv?
                      Ser at "gutta" i USA kjører 4.5T på denne utendørs.
                      I min havner det en Tekin RX8 ESC med Tekin SCX4 4.5T motor og 7.4V 6000mAh 65/130C batterier
                      Bør bli moro nok det
                      Bent
                        I min havner det en Tekin RX8 ESC med Tekin SCX4 4.5T motor og 11.1V 6000mAh 65/130C batterier
                        Også kjent som overkill? Jeg liker det. Burde rive skinnet av pølsa det!
                        Kjenner jeg er bittelitt nysgjerring på hva slags batterier dette er, og om de passer i bilen? Det ser ganske tight ut under reima.
                          Overkill Hva er det ? Kan ikke si jeg kjenner begrepet
                          Dette er de nye Thunder Power G6 Pro Race batteriene.
                          Bruker de samme i Crawlerene mine, men da i 11.1V variant og 850mAh / 325mAh.
                          65C/130C utladning og kan lades på 12C
                          Og ja.....disse river skinnet av pølsa
                          I følge AE skal "alle" vanlige hard case 2S batterier passe i denne.
                          Bent
                            Joda, men...
                            Dette er da 3S?
                            Man får vel noe pusteproblemer når man regner litt på denne pakkas ytelse...
                            Lading - opp til 72A
                            Utlading - 390A kont / 780A peak
                            Jøss, visste ikke at det fantes batteriporno. Disse tallene er bare uanstendige.
                            Forøvrig vil en slik Tekin motor gi 53280 RPM (uten last) ved 3 celler LiPo. Det er nesten dobbelt av en gjennomsnitts Nitro Race motor til 1:8 buggy. La oss si det igjen i kor: PUSTEPROBLEMER! Skinnet-av-pølsa referansen holder ikke her. Vi må oppgradere oss til Plutonium-analogier tror jeg.
                            EDIT! Tekin SCX4 4,5 og 5,5 turn takler kun 2S. Skal du kjøre 3S må du på 6,5 eller 7,5 turn.
                              Joda, men...
                              Dette er da 3S?
                              Ooops.....skulle selvfølgelig være 2S til Short Course'n da.....får da være grenser til å ta i
                              (Gikk litt fort i svingene her....bruker disse i 3S utgave på crawlerene).
                              Disse ERFA godkjente pakkene er 7.4V / 6000mAh / 65/130C
                              Så med 2S og RX8/SC4X 4.5T skulle dette funke som snus.
                              Og ja.....man kan bli svett av spesifikasjonene på disse nye pakkene.
                              Og enda lurer det pakker med helt opp i 90/180C i kulissene.
                              Men i følge leverandør sliter de enda med at disse cellene er noe ustabile
                              Bent
