Paintjobs
  • #46
    Du er dyktig Gunnar!!Hatten av for deg!!
    • #47
      Takk for det Arnfinn.
      Lærer litt mer for hver gang vet du Og noen ganger lærer jeg ei lekse for andre eller tredje gang
      • #48
        Møt Dagros – en av verdens raskeste og smidigste kuer!
        Body: Colt Mini Cooper 2006 1:10 SWB M-chassis
        Paint: Faskolor
        Method: Airbrush
        Masking: Hand cut, free hand
        Stickers: Misc.
        Målet med denne var først og fremst ikke bruke hele lørdagskvelden på hobbyrommet. Ønske nummer to var deretter å lage et karosseri som går litt utenfor den opptråkkede stien – det er fort gjort å henge seg opp i samme spor. Bort med lyn, dauskaller og andre tøffe saker. Her er det kua som gjelder.
        Flekkene er klippet på frihånd ut av selvklebende vinyl, og klistret på tilfeldig her og der.
        • #49
          Lekkert!
          Rett og slett , lekkert!
          • #50
            Hihi, den ble morsom!
            • #51
              Hansa RC
              Body: Protoform Mazda Speed 6
              Paint: Faskolor: Faslucent Purple, Black, White and Silver. Spazstix Mirror Chrome, Candy Gold and Apple Candy Red.
              Method: Airbrush
              Masking: "Homemade" machine-cut
              Stickers: None
              Inspired by a
              beer can design from Hansa Breweries. I saw it and knew I had to paint it.
              "Artistic freedom" is applied in the use of colors, and the logo is also adjusted some, as I had to manually draw quite a bit of the vector diagram before cutting it.
              I have to admit though, that due to laziness, I cut the full Hansa letter twice for each side, and overlapped them for the chrome shaded areas. That turned out to be a bit of a mistake as there was a lot of seepage/paint creep where the top layer of masking went off the bottom one. Next time,
              IŽll draw it as one big mask with shades on the same sheet. Saves vinyl as well
              Also, I let paint build on the needle, and so had splatter in the black shading on the front grille areas and tail lights. More laziness...
ID:	782573 Click image for larger version
ID:	782575 Click image for larger version
ID:	782577 Click image for larger version
              • #52
                Den ble lekker Gunnar!!
                • #53
                  Takk igjen Arnfinn. På tide å få klar noen crawlere igjen også. Var på tur å søndag. Skikkelig moro
                  • #54
                    Hadde vært gøy og kjørt sammen med dere igjen
                    • #55
                      Vi skal holde deg oppdatert Arnfinn. Blir nok noen turer i sommer. Og kanskje med mye folk. Mange i Moss RC som har en på lur nå
                      • #56
                        Det høres bra ut!
                        • #57
                          Custom crawler body
                          Body: Parma '34 Ford
                          Paint: Faskolor Faspearl White, Red and Blue. Spazstix Mirror Chrome.
                          Method: Airbrush
                          Stickers: None
                          I was asked by Roger'n on the forum here if I could finish a body for a custom build he was working on. And being curious about whether or not I could paint what he wanted, I went about drawing stencils.
                          The trouble, as you'll probably see, was of course the stars along the vents in the side of the hood. Luckily it will be hidden somewhat by the shock towers, but nevertheless, I need to find a solution to such problems in the future. But I think it looked good on his truck, and he said he was happy with it as well. Thank you Roger.
                          Another thing I guess I need to learn soon, is how to paint shades on flags to get that 3D effect. That would have looked a lot better here as well.
ID:	782722 Click image for larger version
ID:	782724 Click image for larger version
ID:	782726 Click image for larger version
ID:	782728Click image for larger version
                          • #58
                            Raggae Mini
                            Body: Tamiya Mini
                            Paint: Faskolor Faspearl Green, Red and Yellow. Faskolor Charcoal, White and Satin silver. Spazstix Mirror Chrome, Candy Orange and Candy Red.
                            Method: Airbrush
                            Masking: Provided window masks, "homemade" machine-cut and loads of Fasmask, liberally applied with a teaspoon.
                            Stickers: None
                            This idea came from a pair of Oakley Ski Goggles. The signature series Tanner Hall Crowbars. There is a picture at the bottom of the bag for the goggles, with the theme that caught my eye. And surfing for rasta/raggae stuff on Google, gave me Bob Marley. And so, his not totally unknown silhouette, became part of the car as well.
                            For the random look I was looking for I was thinking about hot glue for a long time. But then the solution came to me, by way of all the bottles I have sitting with Fasmask liquid mask. A teaspoon and three evenings to allow for each side and top to dry, to prevent running or dripping, was all it took. Fasmask is used on grille and front bumper as well. Cut vinyl on lights and Bob.
                            It is for sale for a hefty sum of 900 kroner, until I decide I need it for myself... (The Oakley and the Dripper Minis from previous posts are about finished...)
ID:	782730 Click image for larger version
ID:	782732 Click image for larger version
ID:	782734 Click image for larger version
ID:	782736 Click image for larger version
                            • #59
                              Butburger Speed 6
                              Paint: Faskolor: Faspearl White. Black. Satin silver. Spazstix Mirror Chrome(to make the candy gold pop), Candy Gold and Apple Candy Red.
                              Method: Airbrush
                              Stickers: None
                              I had a Bitburger beer one day, an unpainted Speed 6 body and along came the idea
                              For sale: 800,-
ID:	782741 Click image for larger version
ID:	782743 Click image for larger version
ID:	782745 Click image for larger version
                              • #60
                                Pelle Politibil
                                Body: Tamiya Beetle
                                Paint: Faskolor Faspearl White. Black. Spazstix Mirror Chrome og Tamiya Clear orange og Clear Red
                                Method: Airbrush
                                Masking: Fasmask and self cut lettering and window masks (for chromed edges)
                                Stickers: Taillight and chrome film on taillights.
                                Svar på Steinars Herbie
                                i Moss RC Bilklubb
                                Lys foran og bak, blinkende blinklys og selvfølgelig fungerende blålys... Sitter på en M06 og vil nok ikke bli kjørt så veldig mye
                                Lykteglassene foran ble laget ved å varme opp lexan til den "smeltet", for så å presse de originale plastdelene til lyktene i kitet inn i en svamp for å forme glassene. Litt varm lexan boblet litt, men da ble lyktene bare passe diffuse
ID:	783307 Click image for larger version
ID:	783309 Click image for larger version
ID:	783311 Click image for larger version
