Mugen Seiki MBX-6 ECO
    Fant et par lister med tips til hvordan man skal justere bilen på rctech.net. Mulig de har vært publisert her tidligere, men ....
    More Overall Steering:
    Lower shock mounting in on arm.
    Thinner oil
    in front shocks.
    Softer front springs
    Stiffer rear
    springs
    Short rear upper link
    Longer front upper
    link
    Thinner or no front swaybar
    Less rear toe in
    Short
    Ackermann plate
    More Steering Into the Corner:
    Thinner oil
    in front diff
    Less caster
    Stand up front shocks on
    tower
    Front upper link down on tower
    Short ackermann
    plate
    Steering link back on Ackermann plate
    Thinner rear
    swaybar
    Lean rear shocks down on tower
    More Steering
    Mid-to-Exit of the Corner and On-Power:
    Thicker oil in Front
    diff
    More caster
    Lean front shocks down on tower
    Thicker
    rear swaybar
    Stand up rear shocks on tower
    Less Overall
    Steering:
    Front shock out on arm
    Thicker front shock
    oil
    Stiffer front spring
    Thicker oil in front diff
    Thicker
    front swaybar
    More rear toe-in
    Long rear ipper link
    Raise
    front upper link on tower
    Better Jumping Ability:
    Stand up
    shocks
    Stiffer shock springs
    Thicker shock oil
    Smaller
    piston holes
    More anti-sqat
    More downtravel (specially
    front)
    More kickup
    More Rear Traction:
    Long rear
    upper link
    Raise upper link on tower compared to hub
    Lower
    complete lower link
    More rear toe-in
    Thinner diff oils
    Lean
    rear shocks over on tower
    Larger holes, or more holes in
    piston
    Better Bump Handling:
    Adjust shock oil (usually
    thinner, check shock absorbers advice)
    Lean shocks over on
    tower
    thinner diffs
    More rideheight
    More
    downtravel
    Cut tyres inside and outside
    More acceleration
    and forward bite:
    Thicker oil in diffs
    Long upper
    links
    Smaller clutchbell, larger main gear
    Thicker
    clutchsprings
    More stability in long sweeping
    corners:
    Stiffer front springs
    Stiffer swaybars
    Thicker
    oils in diffs
    What to do first on a high traction
    track:
    Stiffer swaybars
    Less
    rideheight
    Smaller piston holes or thicker shockoil
    What
    to do first on a low traction track:
    Lean shocks over
    Larger
    piston holes, or thinner oil
    Long upper links
    More rideheight
    Mugen Seiki MBX-6 Eco | Tekin RX8 / T8 1900KV | Spektrum DX3C | Savöx
      Og del nummer to, med en litt annen vinkling:
      Toe
      Toe is the angle (inwards or outwards) that the tires point when
      the wheel is straight ahead. Toe-in means the front of the tires point inward,
      and toe-out means they point outward. Zero toe means the tires are parallel to
      each other. The biggest effect toe has on the handling of the car is on
      stability. When a car hits a bump or enters a corner, forces on the tires act to
      steer the car off to one side, making the car unstable and difficult to control.
      Toe-in counteracts this, improving stability. Toe-in also causes understeer
      during initial corner entry. Interestingly, toe on the rear wheels has the same
      effect on handling as toe on the front. Toe on the rear wheels is useful for
      tuning the handling of the car as it is exiting corners.
      Front Toe
      "IN"
      Slower steering response
      More straight-line stability
      Too much
      will casuse greater wear at the outboard edges of the tires
      Front Zero
      Toe
      Medium steering response
      Minimum power loss
      Minimum tire
      wear
      Front Toe "OUT"
      Quicker steering response
      Less straight-line
      stability
      Too much will cause greater wear at the inboard edges of the
      tires
      Less Rear Toe "IN"
      Less straight-line stability
      Less traction
      out of the corner
      More steering
      Higher top speed
      Intermediate Rear
      Toe "IN"
      Intermediate straight-line stability
      Intermediate traction out of
      the corner
      Intermediate steering
      Intermediate top speed
      More Rear
      Toe "IN"
      More traction out of the
      corner
      Less steering
      Less top speed
      Caster
      Caster is the angle to which the steering pivot axis
      is tilted forward or rearward from vertical, as viewed from the side. If the
      pivot axis is tilted backward (that is, the top pivot is positioned farther
      rearward than the bottom pivot), then the caster is positive; if it's vertical
      to the lower pivot point then the caster is zero.
      Less Castor (vertical =
      0 castor)
      More OFF POWER steering into the corner
      Less steering out of
      the corner
      More Caster (laid back
      more)
      Less steering into the corner
      More ON POWER steering out of the
      corner
      Benifiets of castor: (more
      positive castor/laid back more)
      Maximizes tire contact pacth during roll,
      braking, and acceleration
      Improves turn-in response
      Increase directional
      stability
      Improved steering "feel" and self-center
      Increases dynamic
      negative camber during turn in
      Castor Vs Camber:
      Camber doesn’t
      improve turn-in, positive caster does.
      Camber is not good for tire wear.
      Camber doesn’t improve directional stability.
      Camber adversely effects
      braking and acceleration.
      Shock
      Absorbers
      The purpose of the shock absorbers is to dampen
      the oscillation of the springs. The dampers not only dampen spring oscillations,
      but they also affect handling during transient conditions (such as the entry and
      exit of turns), but not steady-state conditions.
      More
      Dampening
      Slower shock action = could be unstable on bumpy tracks
      Slower
      chassis weight transfer
      Generally less traction
      Less
      Dampening
      Faster shock action = less chance of tire leaving the ground on
      bumpy tracks
      Faster chassis weight transfer
      Generally more traction
      Springs
      The purpose of the springs is to
      control wheel movement and keep the tire in contact with the road over bumps and
      irregularities. Stiffening the springs front and rear will reduce body roll and
      make handling more responsive, but cause a loss of traction over bumpy surfaces.
      Likewise, softening all of the springs will give more grip on bumpy tracks, but
      increase roll and reduce responsiveness. You can also use the springs to affect
      the car balance. You can reduce oversteer by stiffening the front springs or
      softening the rear. Likewise, you can reduce understeer by softening the front
      springs or stiffening the rear. However, be advised that changing just one end
      also affects fore/aft weight transfer. By softening the front springs, you'll
      also get more dive under braking. Softening the rear will give you more rear
      weight transfer under acceleration, which can give you more traction on the rear
      wheels in straight-line acceleration. Read and understand about "anti-roll bars"
      before you come to the conclusion that you need to change your springs, springs
      should be one of the last, if not the last thing you should change to effect how
      the car handles other than during a bump condition.
      Using Softer Front
      Springs
      More steering
      Used on bumpy tracks
      More 'diving' under braking
      Used more for tight technical tracks
      Using Harder Front Springs
      Less steering
      Faster steering response
      Used on flat tracks
      Minimum 'diving' under braking
      Used more for
      large fast tracks
      Using Softer Rear Springs
      corner
      More front lift
      under acceleration
      Using Harder
      Rear Springs
      Less traction out of the corner
      Used on flat tracks
      Minimum front lift under acceleration
      Used more
      for large fast tracks
      Downforce
      Downforce
      is the aerodynamic force pressing the car down on the track and improves
      cornering grip. This downforce is dependent on forward speed, and increases as
      you go faster. Increasing the downforce all around increases cornering speed,
      but also increases drag, which gives you slower straightaway speed, and you may
      also need to increase ride height and/or spring stiffness to prevent bottoming.
      Likewise, decreasing downforce gives you lower cornering speeds but higher
      straightaway speeds, and allows you to run softer springs and/or a lower ride
      height. Also, you can also use downforce to fine-tune balance at high speeds. To
      reduce understeer, increase front downforce or reduce rear. To reduce oversteer,
      decrease front downforce or increase rear. Keep in mind that these adjustments
      are dependent on forward speeds and has less effect as speeds drop, so you can
      use this to give the car different handling characteristics for different speed
      ranges.
      Differential
      Settings
      Differential's are used to allow the wheels
      on the same end of the car to rotate at different speeds during cornering.
      If
      diff's are set to tight or are "locked" the tires will fight each other as the
      car is turning.
      Front Diff Looser than Rear Diff
      Steering response
      increases
      If rear diff is to tight, the car will understeer into the corner,
      and will cause loss rear end sliding out of the corner.
      Could cause
      oversteer while entering the corner (depending on other settings)
      Rear
      Diff Looser than Front Diff
      Steering response decreases, stability in turns
      in increased
      Could cause understeer or "push" while entering the corner
      Front Anti-roll
      Bar
      The front anti-roll bar affects the amount the
      car’s front end rolls in a turn. As a car enters a turn, centrifugal cornering
      forces cause car roll and weight-transfer to the side of the car on the outside
      of the turn. A very stiff front anti-roll bar increases the load on the outside
      front tire, and decreases the load on the inside front tire (it can help to note
      that a stiff bar will tend to raise the inside front tire, thereby lowering that
      tire’s load). At the same time, this stiff front anti-roll bar increases the
      load on the inside rear tire, and decreases load on the outside rear tire. In
      this situation, the balance of side traction between front and rear ends shifts
      to the rear, and you get a car with a lower amount of steering, but more
      steering responsiveness.
      Don’t get confused between amount of steering
      and steering responsiveness; a car with a soft front anti-roll bar can have a
      high amount of steering, but it takes more time for the chassis to roll and
      transfer weight with this soft anti-roll bar and this creates slow steering
      responsiveness. A stiff front anti-roll bar will create very quick car weight
      transfer and thus very fast steering responsiveness, but with a lower amount of
      steering. In other words, amount of steering refers to how much steering ability
      the car has; steering responsiveness refers to the speed or quickness of the
      car’s steering ability.
      Softer Anti-roll bar setting
      More
      steering into corner
      More steering in the corner
      Slower steering
      response
      Harder Anti-roll bar setting
      Less steering into corner
      Less steering in the corner
      Rear Anti-roll Bar
      The rear anti-roll bar
      affects the amount the car’s rear end rolls in a turn. As a car enters a turn,
      centrifugal cornering forces cause car roll and weight transfer to the side of
      the car on the outside of the turn. A stiff rear anti-roll bar increases the
      load on the outside rear tire, and decreases the load on the inside rear tire
      (it can help to note that a stiff bar will tend to raise the inside rear tire,
      thereby lowering that tire’s load). At the same time, this stiff rear anti-roll
      bar increases the load on the inside front tire, and decreases the load on the
      outside front tire. In this situation, the balance of side traction between
      front and rear ends shifts to the front, and you get a car with less rear
      traction, but more steering responsiveness (refer to the Front Anti-Roll bar
      page for more explanation on steering responsiveness). The opposite happens with
      a soft rear anti-roll bar: relative to the stiff setting, there is now less load
      on the outside rear tire and more load on the inside rear tire. The front inside
      tire also has less load, and the outside front gets more load. Now, the balance
      of side traction shifts to the rear, creating more rear side traction in the
      corner, but less steering responsiveness.
      setting More side traction in the corner
      More traction out of the corner
      Harder Anti-roll bar setting Less side
      Faster steering
      response
      Tires
      The tires are perhaps the most
      important part of the car. You can gain the biggest improvements by installing
      tires with more grip. Tires are available in many different compounds: hard -
      soft. Soft tires have more grip than hard tires, but wear out faster. You are
      also able to mix types front and back. You can reduce oversteer by using hard
      tires in front and soft tires in back. This gives the rear tires more grip than
      the fronts, making them less likely to slide out. Likewise, you can reduce
      understeer by putting soft tires up front and hard tires in back. If you car
      feel's like it is "loose" or "unstable" you may actually want to try a harder
      compound, by using a harder compound the tire will have less bounce, less side
      flex, and will typically offer a much more stable foundation.
      Tires are
      to small:
      Low forward traction
      Low top speed
      Car becomes
      twitchy
      Tires are to big:
      Very slow steering response
      High chance
      of traction rolling
      Tire distortion in turns
      Less stable
      Softer
      Front Tires:
      More Steering
      More wear
      Less stable
      Harder Front
      Tires:
      Less steering
      Less wear
      More stable
      Softer Rear
      Tires:
      More rear traction
      Less steering
      More bounce on bumpy
      tracks
      Less stable
      Harder rear tires:
      Less rear traction
      More
      steering
      Less bounce on bumpy tracks
      More stable
      Camber
      ( PLEASE READ ABOUT CASTOR BEFORE YOU ADJUST YOUR
      CAMBER )
      Camber is the angle the tires make with the road and is measured
      in degrees. Tire grip varies with the camber angle, and ideally is maximum when
      the angle is zero. However, the maximum grip is found with a small amount of
      negative camber because of tire sidewall deflection (when the top of the tire is
      tilted inward it is called negative camber. Also, as the body rolls in a turn,
      the suspension movements themselves causes some adverse camber change. These
      combined effects mean that for maximum cornering power you need to have some
      amount of negative camber. However, too much camber will cause you to lose grip
      because the outside edge of the tire is being lifted off of the pavement,
      reducing the contact patch. So to summarize, as the camber angle increases from
      zero, cornering grip improves to a point, then falls off.
      -2 deg. ~ -1
      deg.
      Front Camber
      More overall side traction
      Less chance of traction rolling
      -1 deg. ~ 0 deg.
      Front
      Camber
      Less quick steering response
      Less overall side traction
      More
      -2 deg. ~ -1 deg.
      Rear Camber More overall
      side traction
      More traction under braking
      rolling
      -1 deg. ~ 0 deg.
      Rear Camber Less overall side traction
      Less traction under breaking
      More chance of traction rolling
      Gear Ratios
      General:
      Gear ratio
      affects the balance between a car’s acceleration and top speed. A small clutch
      gear with a large spur gear produces a high gear ratio (the figure is a high
      number, the gear is called "short") gear ratio, giving faster acceleration but
      lower top speed. A large clutch gear with a small spur gear produces a low gear
      ratio (the figure is a low number, the gear is called "long" / "tall"), giving
      slower acceleration but higher top speed.
      Measurement:
      Gear ratio is
      measured by simply dividing the spur gear (two speed) teeth number by the pinion
      gear (clutch) teeth.
      Adjustment:
      You can change the clutch and
      two-speed gears independently or together to get different gear ratios. This
      applies to both first and second gear. Remove a gear and replace it with one of
      a different tooth number. YOU MUST add the teeth number up between both first
      and second gears, they must equal the same. For exaple if first gear spur is 47
      teeth and first gear pinion is 17, add 47+17=64. Then add your second gear spur
      and pinion, 20+44=64. This will ensure that you will have the same mesh on both
      gear's as long as you have mounted your engine straight.
      Lower gear ratio
      (longer gear)
      lower acceleration,
      higher top speed
      Higher gear
      ratio (shorter gear)
      higher acceleration,
      lower top speed
      Ride Height
      A lower ride height lowers the center of
      gravity, which reduces weight transfer during cornering, acceleration, and
      braking. The reduced weight transfer improves cornering. A lower ride height
      also lowers drag at high speed because you are presenting a smaller frontal
      profile to the airstream. Also, by lowering the front end and raising the rear,
      you can improve high speed stability and increase downforce by preventing
      high-pressure air from building up underneath the nose of the car. If the car is
      too low, it can bottom out, though this can be eliminated by stiffening the
      springs(which could cause problems elsewhere).
        Du bør også lese setup guiden fra Hudy (den er postet en annen plass på radiostyrt.no hvor jeg hentet den fra);
        http://www.google.no/url?sa=t&rct=j&...g6X0pb_XPPKy0Q
        Den er spesifikk for xray men prinsippene er de samme for de fleste bilene.
          Masse justeringer ja, men jeg syns standardoppsettet til Mugen er bra. Bare ha i 4000 olje i bakdiffen. Tror du skal prøve den som den er satt opp i første omgang, og så bare justere en ting om gangen...
            Sjekk ut også Hudy's setup guide;
            Den er mer altomfattende og den er generell for de fleste biler fordi om den er skrevet spesifikt for Xray.
              Bortsett fra surfing på diverse andre nettsteder går tiden med til å vente på pakker fra den andre siden av dammen, og en fra østerlands rike. Er innom garasjen minst en gang for dagen for å ta på og se på
              Har jo egentlig planlagt denne bilen som et vinterprosjekt, men vet med meg selv at jeg er så utålmodig at det er stor sannsynlighet for at det blir gjort en liten prøvekjøring rimelig kort tid etter at motor og regulator er i hus....så da får vi se om det blir utendørs på banen på Hegstadmyra eller i parkeringshuset på Tillertorget (lokalt kjøpesenter). Vinteren lar jo vente på seg, så man kan jo alltids håpe på en utetur....
                Takk for tips
                Skal sjekke ut den også!
                  De to reglene på forrige side er hentet fra den offisielle tråden om MBX-6 ECO på rctech.net. Har lest side opp og side ned om akkurat det du sier - bruk tykkere olje enn originalt i bakdiffen, så er du på god veg. Standardoppsettet på bilen skal være så bra at det stort sett ikke er mer som skal til for å ha et topp oppsett.
                  Da blir spørsmålet - hvilken olje og hvor handler man? (skjønner at du anbefaler 4000 i viskositet, men har fått med meg at det er flere som mener det er forskjeller mellom de forskjellige leverandørene også...?)
                    Kun erfaring med Associated og Losi oljer, og synes begge funker. Men du får kanskje andre synspunkter her?
                    Selv har jeg blandet 50/50 innen et merke for å få 4000 olje (5000+3000)/2.
                      Får vel ta en tur innom smallsize og bunkre, da, tenker jeg
                      USA-pakken er forresten tollklarert, ser jeg på posten sine sider
                      Da havner den vel plutselig i min postkasse en av dagene
                      Sendingen er sortert og videresendt
                      04.11.2011 09:12 0024 OSLO
                        Da var endelig regulator og motor i hus Tror jammen meg at vi da har alt som skal til for å få fart på bilen nå, gitt
                        Må sette opp ei liste over hvilke reservedeler som må handles. Øvre + nedre bærearmer, drivaksler, dempere, ... osv
                          Måtte jo prøvemontere motoren i går kveld.... Støtte da på en mulig utfordring...
                          Dersom jeg vil ha polene til kablene pekende rett opp må jeg bruke de minste monteringsskruene. Hvis jeg skal bruke de store blir motoren stående på hodeet, og det er en smule upraktisk.... Går det an å åpne motoren og vri 'frontplata' på den, slik at skruehullene passer bedre?
                          Reservemotoren er enten montert 'riktig' fra fabrikk eller vridd i ettertid, for der kan jeg bruke de store skruene når polene peker oppover....
                          Takknemmlig for svar
                            Så lenge det er Tekin T8 vi snakker om er bare å åpne den i front (tomme skruer) og vri den slik at den passer best. Har gjort det på alle mine oppsett
                              Da er en veldig kort første prøvetur unnagjort ute i gata...
                              Fy F hvor det går! Wheelies på våt asfalt gikk så det grein. Følte jeg kunne holde den oppe akkurat så lenge jeg ville. Samtidig - hvis jeg ikke var like brå på gassen fra start var virket det som om bilen sugde seg ned mot asfalten og bare dro av gårde. Helt konge Mine gutter og kompisene som kikket på løp som pokker når jeg tok løs i en grusdunge he he......småstein kom fort flygende gitt
                              Bare .en liten 'glitsj' - Den ble vond å få i revers etter ei lita stund. Et lite nugg på styringa, så virka reversen igjen.... Må vel forske litt på årsaken til akkurat det.
                              Batterier var forresten to stk Orion Rocket 2S 4000MaH 30C i serie.
                              Gleder meg til fortsettelsen
                                He-he. Det oppsettet går unna ja
                                Bare vent til du kjører på bane, og du må holde litt igjen for ikke å hoppe for langt... utrolig gøy!
                                Bare sjekk tidsforsinkelsen på regulatoren (fra framover til revers), det er litt forsinkelse for at du ikke skal ødelegge motoren.
                                Hvis du ikke har noe annet problem da.
                                Batteriene er akkurat nok til å holde unna, 2050kv drar vel nærmere 100 mA, og batteriene gir 30x4=120, dvs nesten 100 mA med 80% belastning.
