Kyosho Mini-Z MR03....
  • dette håper jeg er komplett liste over alt som er bestilt....
    1 x MINI-Z Racer MR-03 Chassis Set AFS
    1 x Porsche 911 GT3 RSR No.45 ALMS 2006
    1 x L.C.G Motor Pod LM V2 - Blue ( For MR-02 / 03 WB 102-106mm)
    3 x Mini-Z DPS Mount (2.8mm) for MM
    1 x MR-02 DPS Conversion (for LM-102mm WB)
    1 x Kyosho Mini-Z Main Chassis Set for MR-03
    1 x PN Mini-Z MR-02 Front Wheel - +0 Offset - White
    2 x PN Mini-Z MR-02 Front Wheel - +1 Offset - White
    2 x PN Mini-Z MR-02 Rear Wheel - +1 Offset - White
    1 x PN Mini-Z MR-02 Rear Wheel - +3 Offset - White
    2 x PN Mini-Z MR-02 64 Pitch Delrin Ball Diff Spur Gear 53T
    2 x PN Mini-Z MR-02 64 Pitch Delrin Pinion 10T - 2PCS
    1 x Kyosho Route 246 R246 Mini-Z Roll Damper/ Oil Shock Set for MR-03 RM
    2 x Racing Mini-Z Graphite Rear Suspension T-Plate Set for MR-03 RM/HM
    1 x Kyosho Ball Diff Grease (15g)
    3 x Atomic AR103 Mini-Z White Dish Wheel Front +1 Offset
    3 x Atomic AR108 Mini-Z White Dish Wheel Rear +1 Offset
    1 x Atomic AR109 Mini-Z White Dish Wheel Rear +2 Offset
    1 x ASC MR015RM, Porsche 935 Turbo 1977 Jägermeister
    5 x Personal Transponder
    3 x kyosho dempere (gule-settet)
    2 x komplett RR front
    2 x PN T-plater #4 til MM
    2 x kulelagersett
    20 x løse front kulelagre
    1 x 200 grams vekta
    1 x Ferrari 360 GTC hvit karosseri
    2 x PN Racing Mini-Z MR02/03 V2 Light Weight 64P Ceramic Ball Diff. Set
    1 x PN Racing Mini-Z MR015/MR02 RM Motor Mount (Orange)
    2 x PN Racing GiroZ i-Lap Silicon Wire Connector for Mini-Z 2.4 ESC (1pcs)
    1 x PN Racing Mini-Z MR02 Ball Diff E-Ring (10pcs)
    3 x PN Racing Mini-Z MR03 High Clamp Force T-Plate Mount (Orange)
    1 x PN Racing Mini Car Foam Stand (Orange)
    1 x Atomic Mini-Z MR-02/MR-03 90mm Aluminum Motor Mount - Gun Black
    1 x Atomic Mini-Z Alloy DPS Set for MR-02/MR-03 Alloy Motor Mount - 90mm WB - Black
    1 x Kyosho Perfex Limited Edition EX-5UR ASF 2.4GHz 3 Channel Transmitter (Red)
    Den siste linja er den senderen jeg har kjøpt. Dessverre rød, men pytt pytt.
    Da finner jeg den vel igjen. Er den billigste "kjipe" men med de fleste muligheter. Orket ikke å begynne å modifisere Futaba 4PK'n jeg har liggende.
    • La til MM motorfeste for 90mm også, samt da DPS for den.
      De er jo på veui, men jeg har jo ikke mottatt dem enda.
      Altfor mye kjøpt inn, men sånn går det innimellom.
      Håper det nå er kun noen få felger som mangler, hvis det mangler noe.
      Da burde det "kun" være dekk og dekktape igjen som må kjøpes inn.
      Men slikt er forbruksvare, så det må jo kjøpes inn "hele" tiden.
      • Grei liten handleliste det der. Kult å ha mange biler da
        • det er kun en prioritering.
          Jeg liker å ikke skru på mtorfeste hver gang jeg vil bytte bil, samt at de fleste nå da har forskjellig motoroppsett. RM, LM og MM.
          Så nå blir det litt å bryne seg på.
          Blir "mye" leMans da...og mye porscher
          • Pokker, ser ut som at Posten har rotet vekk en pakke med MM motorfeste og Diskdemper....
            Uff, slikt liker jeg ikke.
            • Grrr.
              Får håpe RM festet ditt kommer etterhvert da
              • Aner ikke med de andre delene.
                Men dette er jo til Vitz'n som jeg ville ha klar. Har bare ventet i 3 uker nå, så det er fortsatt mulighet.
                Håper bare jeg får det, for det blir litt penger ut av vinduet hvis posten skal stjele fra meg....
                • Du har forresten en jobb å gjøre her:
                  Se hva jeg har svart, og se om du er enig
                  • hihi
                    Jeg så den tidligere.
                    Lurte på om jeg skulle svare, men kom til at jeg ikke trengte å begynne der som jeg holder på her...
                    • Så sant, så sant.
                      Men her har du jo mulighet til å påvirke hvilke biler som skal være tilgjengelige...
                      • f.eks. Porsche Carrera RS73.....
                        • Har et Porsche 911 GT3 sølv / rødt karrosseri med tilhørende felger, hvis noen trenger det.
                          Fikk begge chassiene i dag og senderen min.
                          Så da er det bare å vente på resten av forsendelsene.
                          • Lurer på om jeg vet om en som er hypp...
                            • hm...
                              Mangler visst fjærer til DPS.
                              Glemte o-ringer til diffene.
                              Har ikke nok koblinger til Robitronic transponderene.
                              Lurer på hva mer jeg mangler. Må vel kanskje vente å se hva som eventuelt mangler når jeg får inn alt.
                              • Men du har hvertfall masse differ nå
                                Eller hvertfall etterpå...
